I know there is several methods to recapture the wasted energy we consume daily, heres a simple one I'm working on building. I live on a hill, every day I leave to work, my truck (F-250 powerstroke) about 7000lb. of pure kinetic energy, is going to make me free energy, its free because it is being wasted away right now by using breaks to slow down going down my drive way! THINK OF A HUGE GRANDFATHER CLOCK THAT YOU USE YOUR VEHICLE TO WIND. A large mass (like dirt or ? in a heavy duty container) is hoisted in the air via a cable attached to truck, going down hill and loads multiplied by pullys, lifting 20,000lbs should be no problem, if I want to use the trucks pulling capacity as well, I'm sure I could lift a object at least 50,000lbs in a short distance of 50' feet. A little effort of hooking up cable and unhooking provides huge returns in stored energy (Kinetic), now put it to use, geared down, running a 2000 watt generator during peak hours! During energy shortages, power company's triple their rate on peak hours, so no vehicle, no problem, just hoist weight into air with winch at off hours and start producing power on peak hours, they have to sell it back at the rate they give it. Until we have the E.V. Gray motor in every household (hopefully sooner then later), simple mechanical ideas like this can help offset the the Governmental power conspiricy/slavery/thievery/scandal. Its ALL ABOUT EMPOWERMENT-----------RIGHT?-------------
Added: a simple devise from inventor Wilkinson shows the clock work portion wilkinson machine - YouTube I just found this link under "Energetic Science Ministries" called "Electronic multiplier machine" posted from One_Christian_warrior
