Testing Measurements...
Hello Carroll,
Yes, that is what I meant, tin coated wire, it is more expensive, less chances to rust on a Marine environment...
That Meter I borrowed from a friend,it just could be defective...I have others but do not get to High Amps, only 40...I use those next time on AC Generating...don't think will ever go higher than 40 there. Even though that Generator Outputs 120V/50A, and I am not regulating speed, My Motor reaches 4400 to 4600 RPM's at no load at Generator, then I get 160V AC...it drops down to 3400 under load, which is within allowed rate to keep @58 Hz
Where I am having problems is at the DC side, they jump from High to Low at very fast pulsing rate, it is DC Pulsed...not linear at my Motor, and really have no idea how to measure DC Pulsed Amperage to be steady.
The drops and up amps range are of a too wide scope, say from 23 goes to 16, then to 28-29 then back to 16 amps...and it is very hard to keep a constant or average there. I have tried an AC Cap, an Electrolytic...but don't make any difference at all.
Someone told me about a 12 feet wire of 8 gauge, a shunt...do you think that will make a better reading there?
I do not have an Amp Probe, and have no idea if My Scope will read that way amps...it is not written anywhere on Manual it will read amps.
Any suggestions, I will give it a try
Thanks and regards
Thanks and regards
