Originally posted by bistander
First, John Stone did not "questioned" me just like that, directly. He just asked me in order to clear doubts for other skeptics not to be holding from that possibility...like you have been doing so far.
On my answer I just made it clear and calmly the way I was hooking up the DC Clamp meter, by stating it was in the common end and not in one of the "Y" terminals...so I was not exactly "jumping" like you've said.
Also, in the video, it takes about 3 or 4 seconds for the meter to settle in at 43.9A changing very little; only 2 or 3 tenths of a Amp.
I don't know why it was such a high no load reading back then. I believe you said something about a bad bearing in the generator. Even that doesn't seem like a 40+ Amp load. But it was what the meter read.
I am not about to wind a motor like that to repeat your test. I have over the years run dozens of motor-generator tests and rotary converter tests. 63% efficiency on a 36V, 1kW system is much more likely than 124%. If you knew what you were doing and saw 124% efficiency, why didn't you go to extraordinary measures to verify that? How about rerunning the test several times? With a different load amount? In front of an eye witness? I know if I ever demonstrated 124% efficiency on my bench, the experiment would stay intact and unaltered until I was able to get an expert to witness it.
I am not after just a "debatable" 25% in excess...and I was not happy with that particular test, as I wrote there as well to one of the members.
For me to see a "wrestling fight" between two nice sized machines in order to see which one wins is not the answer we are all looking for...it does not lies there at all.
All my recent research and development confirms with facts I was right by NOT following that path.
I am not going to convince you and you're not going to change my mind regarding that test unless you demonstrate 124% legitimately. So just end it here.
I quickly deduced that since the motor speed was 1725rpm (when run as a motor), it needed 4 poles on the rotor to get 2 cycles of AC sine wave per revolution. So my rotor design of bipolar was for a 3600 rpm generator, not at all going to work with the coil designs of this stator. Finally knowing what works to handle neos, I have quickly rebuilt the rotor into the quad pole (2N & 2S poles). Cut the total number of neos in half to get the rotational magnetic drag under control. Standby, epoxy curing...
