Great...getting organized now.
Hello Midaz,
So far you have done an excellent job building/winding this Machine!
Now, you will need to get organized a bit related to connections and readings of parameters required:
Connections are simple for now:
[IMG]
[/IMG]
A better circuit would be with independent switches for each gate like shown above. Toggle Switches need to be rated -at least- 50 Amps.
See if you could add an RPM reading with Tachometer on black painted shaft with reflective tape.
Ideal deal would be to be able to read all required parameters: DC Batt V, DC Amps Draw and RPM's. However, RPM's would tell you if you need to tune better the timing/firing of coils.
Use My 12V Test Video below, as a guide to see MAX RPM's that you could take out of it when it is fine tuned with each Gate On, one by one...then all:
IMPERIAL_RPMS_TEST_12V - YouTube
I also did a 36V Test ... to compare, whenever you get there...
Regards Midaz
[IMG]
[/IMG]A better circuit would be with independent switches for each gate like shown above. Toggle Switches need to be rated -at least- 50 Amps.
Regards Midaz
