RPM's VS Force
Hello Hitby13kw,
In this type of Asymmetrical Machines, it is very important to have a pretty high RPM's at low feed...it means our machines are more robust...as Rotor Bisectors are "Firing", as close as possible to stators bisectors on the side of rotation at rotor end...this generates Stronger Throw Out Forces.
This proper timing not only offers a good RPM's/Speed, but it is a sign that they are running much stronger when facing mechanical loads.
In this Machines Speed/Force/Power run together as they are directly proportional...(while in Symmetry they are inversely proportional)meaning, a fast motor will generate a higher torque than a slower one with same feed.
Try disconnecting your motor from Generator Head shaft...then test and compare.
Your resistance is OK "about" 1.0 ohms...now, is it passing 1 ohm?...or below?
Mine is from 0.6 to 0.8 per Pair.
Originally posted by Hitby13kw
Hello Hitby13kw,
but after watching your video (Thanks again for relisting it) the major difference between our setups is my lovejoy couplings to the generator were still connected when the test was made (will put that on my to-do list) . . . Our resistance per pair is about one ohm.
) instead of Motor Gates, so, the Positive is common and goes to all bulbs...and one channel from Drain to each independent...and see if they stand the speed of pulses without locking any FET's...
uncoupled the Imperial form the generator head, ran a comparison test to the above 12V test, can match your RPM, but it takes me two batteries 24V to do it. When I had trouble before you had cleared me of a diagnosis1 fault after viewing
[/IMG]
doN'T Let Hitby hear/read about this, please!!)
