I will work on it for you...
Hello Wantomake,
Ok, I will prep a Diagram for You...I do not have a 16 Pole Pattern in CAD...so I will have to start from zero...but I will render it soon.
Now, some interesting tests you could do with your machine now...coupled to one of your Generators heads...is to add to Generator under a known load given in Watts...versus what V and A the Prime mover (Asymmetrical Modified) is taking...so it is Watts In against Watts Out...and let's "disregard" the Asymmetric Machine output for now...in order you could inject also through the Output like you did before(Turbo Boost)..in case when load applied to Generator Head...RPM's drop too much...
I want you to run the Generator Head with either one of your Mod's...one you have now or the one I will give you...and I want you to be witness that you will be outputting higher Watts than In...I want to finish this "dilemma" of up to now a "fiction" once and for all...and is great you have Gen Heads!!
Whenever you have a chance tell Us what kind of Wattage the Heads output...
Edit: You can NOT apply the Turbo Boost for too long!!...it will get hot!...since you are not releasing ANY output...Armature will overload...Ok?...But you could do it "just in case" it is required...but play with different loads...from small to higher first, with normal Input...
Thanks!
Originally posted by wantomake
Hello Wantomake,
Thanks!
Anyways please update us on your progress Thanks
