BrovinKacherTesla
  • #16
    questions to scratchrobot
    Originally posted by scratchrobot View Post
    I tried to charge cap between L2 and ground and av plug and cap charges very well.
    capcharge.MOV - YouTube
    Hi scratchrobot,
    thanks for publishing that video
    and also for the other videos on your youtube channel
    scratchrobo - YouTube
    The capacitor you charge in the video, is that from a microwave oven? And did you "operate" it, i.e. take the resistor out?
    If that is the case, did you afterwards refill it with the original liquid electrolyte or did you use another liquid?
    And regarding the oscillator circuit you use in your video
    hv-driver.MOV - YouTube
    Is there a schematic available, somewhere?
    • #17
      Originally posted by marxist View Post
      Hi scratchrobot,
      Yes the cap is from an microwave oven and i removed the resistor, i bend it open vrom the top and did not spil any oil.
      I will draw a schematic of the circuit i use.
      • #18
        Hey Scratch,
        Your last video is impressive!
        Any values on current draw for that full brightness ?
        When you say RESONANCE v Non RESONANCE - what are you implying?
        Regards, Penno
        • #19
          more questions
          ....will draw a schematic of the circuit ...
          Hi scratchrobot,
          thanks for answering and offering to provide the circuit drawing.
          Some more things that interest me:
          1) the feedback oscillator shown in your newest videos, for example in
          Resonant coil - YouTube
          is that an "evolution" of the older version?
          Did you make that printed circuit board for it?
          What is better in this new version compared to your old oscillator?
          2) The resonant coils in that same video
          Both coils are evidently different from each other, i.e. the left one has a bigger diameter.
          So: when you made them, did you purposefully wind them, to make them resonant, or is the resonance achieved purely by the position of the red antenna?
          If the antenna's position is not solely responsible for resonance, then what parameters of the two coils must match, to achieve the effect shown in the video?
          PS I am sorry to create work for you, like make you answer questions and draw diagrams.
          • #20
            Hi scratchrobot,
            Don't feel sorry because i'm happy to help you.
            I used the same circuit in all my videos. It is just an 555 to start the oscilation and then the antenna (red wire) takes over. The circuit works with any coil, the antenna creates resonance. I'm sorry i have no time now to draw the circuit but i will do it tommorow.
            • #21
              Originally posted by penno64 View Post
              Hey Scratch,
              Regards, Penno
              When i say resonance i mean the antenna takes over to get resonance frequency, normaly the circuit runs at 100khz. When at resonance the current draw goes down and bulp is bright. I connect bulp at bottom of L2 coil.
              • #22
                That would be great. I am looking forward to seeing how you do this. Thanks for offering to post the circuit.
                • #23
                  Hi all
                  some update
                  hope this helps
                  good luck at all
                  Laurent
                  charging by induction approach 2.wmv - YouTube
                  • #24
                    Hi woopy,
                    I am a big fan of your work.
                    Here are some text book style answers to your questions. The "cold electricity" is actually RF frequency AC. When you have sinusoidal AC the voltage is half the time positive and half the time negative. On a scope you can see this, but on a voltmeter the positive and negative parts cancel each other out. So the meter reads zero (because the meter can not respond fast enough to show the changing voltage). The current is also half of the time going one way and the other half going the other way which causes a DC amp meter to read zero since the needle can not go back and forth as fast as the current so it just stays put. This will also cause a compass held near wire to not be effected by the AC current since again the needle can not go back and forth as fast as the current changes. The wire around the battery is the secondary of a transformer with the primary being the current flow in the battery. Current is flowing out of the battery at RF frequency. Putting a capacitor across the battery will reduce this RF current flow in the battery. Note that in many circuits high voltage spikes are being fed back into the battery which can be capacitively coupled to a plate. As the frequency of the AC increases the current flows more and more along the surface of the conductor (including you). At RF frequencies the current is only hundredths of an inch deep and not as deep as the nerves in your skin. That is why you do not feel a shock from RF current. However, if the current is strong enough it will burn your skin (called RF burns).
                    • #25
                      Hmm...then we should investigate ways to construct shield against that RF field.
                      Woopy : Can neon tube be lit near the battery container or it will require you touching the battery box with one terminal of neon tube while grasping by hand the center or tube or other end ?
                      • #26
                        Wow you managed to bend the top of the cap?!!!! Mine I made a cut and had to do silicone. Maybe I will try to bend it open next time as you've did.
                        Thanks for sharing.
                        • #27
                          Hi Xee2
                          thank's for the writing, very interesting , will read more about those RF
                          Hi Boguslaw
                          Yes every CFL lights more or less depending on the Kacher i use. It seems that when i use my long Kacher (Slayer exciter ) the CFL light is very powerfull and the frequency is low (about 350kHz). With my super flat Kacher where the frequency is much higher (about 1 MHz ) the CFL reacts less good. But both can create the arcing in the car coil.
                          Hope this helps.
                          Good luck at all
                          Laurent
                          • #28
                            Originally posted by woopy View Post
                            Hi Xee2
                            Hi Boguslaw
                            Hope this helps.
                            Good luck at all
                            Laurent
                            No,no. I mean : if you place kacher at distance from battery so far away that kacher should not light neon tube wireless I would like to know if neon tube can be lit by touching it to battery plastic or maybe even battery will spread field to near air. But surely you have to place it far away from kacher so the air ionization from kacher can be dismissed as a source of energy. Then your theory can be proved.
                            • #29
                              Kacher
                              What transistors can be used other than MJE13009 for this circuit?
                              Is the source battery charging as I understood in the vid?
                              • #30
                                OK Boguslaw
                                here is probably what you wanted to see
                                good luck
                                Laurent
                                charging by induction approach 3.wmv - YouTube
