  • Name list of the Temples with a 3 6 9 twist ( for the others follow the link and check out the distances between each temple )
    Pilgrimage on Shikoku Island
    Temple
    3 Golden Spring Temple
    6 The Temple of Everlasting Joy
    9 The Dharma Wheel Temple
    12 Burning Mountain Temple
    15 The Official State Temple
    18 The Temple of Gratitude Mountain
    21 Great Dragon Temple
    24 Cape Temple
    27 God Summit Temple
    30 The Temple of True Joy/The Temple of Everlasting Joy
    33 Snowy Cliff Temple
    36 Green Dragon Temple
    39 Emitting Light Temple
    42 The Temple of Buddha's Tree
    45 Rock Cave Temple
    48 West Forest Temple
    51 Stone Hand Temple
    54 The Temple of Long Life
    57 The Temple of Good Luck
    60 Side Summit/Peak Temple
    63 The Temple of Mahasri/Laksmi
    66 Hovering Clouds Temple
    69 The Temple of Kannon
    72 Mandala Temple
    75 Right Path Temple
    78 The Temple of Illuminating Local Site
    81 White Peak Temple
    84 Roof Island Temple
    87 Long Tail Temple
    ps: Temple 46 : Pure Emerald Temple
    Signs and symbols -Confucius.
    • It just occured to me
      what happens if we apply 369 to the Table Elements
      List of Elements of the Periodic Table - Sorted by Atomic Number
      Element 3: Lithium
      Element 6: Carbon ( you are carbon based fellow fractal antenna )
      9: Fluorine
      Element
      12: Magnesium
      15: Phosphorus
      18: Argon (Noble Gas )
      21 : Scandium
      24: Chromium
      27: Cobalt
      30: Zinc
      33: Arsenic
      36: Krypton
      39: Yttrium
      42: Molybdenum
      45: Rhodium
      48: Cadmium
      51: Antimony ( often referenced in alchemical treaties )
      54: Xenon ( Noble gas )
      57: Lanthanum
      60: Neodymium ( used to make magnets )
      63: Europium
      66: Dysprosium
      69: Thulium
      72: Hafnium
      75: Rhenium
      78: Platinum (used in water electrolysis )
      81: Thallium
      84: Polonium
      87: Francium
      90: Thorium ( a possible alternative to uranium for nuclear energy )
      93: Neptunium ( Neptune Anyone ; Neptunium (named for the planet Neptune, the next planet out from Uranus, after which uranium was named) )
      96: Curium
      99: Einsteinium
      102: Nobelium
      105: Dubnium
      108: Hassium
      just a reminder:
      Element 13
      is Aluminum
      interesting .....
        just a reminder:
        Element 13
        is Aluminum
        interesting .....
        just out of curiosity ....let's check the other 13's
        Elements
        49 ( 4+9= 13 )
        : Indium
        58 : Cerium
        67 : Holmium
        76 : Osmium
        85 : Astatine
        94 : Plutonium
        103: Lawrencium
        a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
        • http://en.wikipedia.org/wiki/Trinity_(nuclear_test)
          Trinity was the code name of the first detonation of a nuclear device. This test was conducted by the United States Army on July 16, 1945,[4][5][6][7][8] in the Jornada del Muerto desert about 35 miles (56 km) southeast of Socorro, New Mexico, at the new White Sands Proving Ground, which incorporated the Alamogordo Bombing and Gunnery Range. (The site is now the White Sands Missile Range.)[9][10] The date of the test is usually considered to be the beginning of the Atomic Age.
          Trinity was a test of an implosion-design plutonium device. The weapon's informal nickname was "The Gadget".[11] Using the same conceptual design, the Fat Man device was detonated over Nagasaki, Japan, on August 9, 1945. The Trinity detonation produced the explosive power of about 20 kilotons of TNT.
          Coordinates: (note the 33 degrees coordinate )
          = 33+40+38+28 = 139
          = 106+28+31+44 = 209
          = 139 + 209 = 348 = 33 = HM 6
          see Bruce Cathy's work (previously discussed )
          94 : Plutonium = Temple 13, Dainichiji The Temple of the Great Sun
          • Self-awareness in humans is more complex, diffuse than previously thought
            Ancient Greek philosophers considered the ability to "know thyself" as the pinnacle of humanity . Now, thousands of years later, neuroscientists are trying to decipher precisely how the human brain constructs our sense of self.
            Self-awareness is defined as being aware of oneself, including one's traits, feelings, and behaviors. Neuroscientists have believed that three brain regions are critical for self-awareness: the insular cortex, the anterior cingulate cortex, and the medial prefrontal cortex. However, a research team led by the University of Iowa has challenged this theory by .
            ......What this research clearly shows is that self-awareness corresponds to a brain process that cannot be localized to a single region of the brain," said David Rudrauf, co-corresponding author of the paper, published online Aug. 22 in the journal PLOS ONE. "In all likelihood, self-awareness emerges from much more distributed interactions among networks of brain regions." The authors believe the brainstem, thalamus, and posteromedial cortices play roles in self-awareness, as has been theorized.
            COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
            An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
            . a harmonic cascade effect
            ------------------------- also from a great man (full of info )
            Jordan Maxwell - The Chief Cornerstone - YouTube
            • crop circle update:
              Hackpen Hill (3), nr Broad Hinton. Wiltshire. Reported 26th August.
              Crop Circle at Hackpen Hill (3), nr Broad Hinton. Wiltshire. Reported 26th August** 2012.
              New Crop Circle Hackpen Hill Cube, page 1
              Beautiful, reported yesterday, August 26th.
              I wonder if the 6's have any significance? If you count the other sides you can't see, you get 216 individual squares. (36 X 6).
              similar to :
              from: http://www.energeticforum.com/psychi...tml#post198875
              Numbers and their Meanings - Crystalinks
              Thirteen (13)
              13 = (1+3) = 4 = closure of our reality program or the evolution of consciousness back into light.
              4 also references the number 40, given significance throughout history. Year 40 was a leap year starting on Friday of the Julian calendar.
              13 is a Fibonacci Number (F7).
              13 is the 6th prime number. 6 is sometimes considered an unlucky number due to its association with 666 (18=9=closure).
              13 is the second Star Number.
              There are 13 circles in Metatron's Cube.
              13 is the atomic number of aluminium . In chemistry and physics, the atomic number (also known as the proton number) is the number of protons found in the nucleus of an atom. It is traditionally represented by the symbol Z. The atomic number uniquely identifies a chemical element. In an atom of neutral charge, atomic number is equal to the number of electrons. The atomic number is closely related to the mass number, which is the total number of protons and neutrons in the nucleus of an atom.
              • a repost from: http://www.energeticforum.com/psychi...tml#post203083
                You seem to have connected lots and lots of dots in the PMR (Physical Matter Reality, what is commonly called, simply, reality).
                Ask any good Hacker .... Knowing how the Networks work is step 1 to Hacking your Reality / PMR
                http://en.wikipedia.org/wiki/Hacker_(computer_security)
                Hacking means finding out weaknesses in a computer or computer network, though the term can also refer to someone with an advanced understanding of computers and computer networks.[1]
                as in Meta - Tron 13
                  crop circle update:
                  It is interesting to note that there is a 4*4 board on each face of the cube
                  you know what has also a 4*4 board that would fit nicely on each face :
                  Magic square - Wikipedia, the free encyclopedia
                  The magic constant of the square is 33 , the age of Jesus at the time of the Passion. Structurally, it is very similar to the Melancholia magic square , but it has had the numbers in four of the cells reduced by 1
                  Melancholy Square:
                  Agrippa
                  Chap. 60. Of Madness, and Divinations which are made when men are awake, and of the power of a Melancholy Humor, by which Spirits are sometimes induced into Men's Bodies
                  .:: Kenneth Bager - Fragment Eight (The Sound of Swing) ::. - YouTube
                  by the way many of you have probably played a version of magic square and probably playing with magic unkowingly :
                  you are familiar with SUDOKU
                  The Sudoku Experience: Sudoku History
                  Sudoku History
                  Did you know that Sudoku was originally called Latin Squares? It was invented by a mathematician called Leonhard Euler in the 18th-century. As his eyesight started to fail, he developed the ability to perform complex equations in his head, as well as a talent for designing puzzles.
                  Then in the 1970's it reappeared as the Number Place Game in America. In the 1980's it was picked up by a Japanese puzzle publisher and called Sudoku (pronounced sue-doe-koo). The name is Japanese; su - "number" - and doku - "single"; in kanji it is written 数独. The monthly Sudoku puzzle magazines in Japan currently have a circulation of around 660,000.
                  • a bit of fun ... call it synchronicity playing its symphony :
                    100-year-old mystery package opened
                    A highly anticipated moment delivered underwhelming results after a mysterious century-old package labelled 'Can open in 2012' was unwrapped on live television.
                    The people in the small town of Otta in Norway waited 99 years and 363 days to open the package, which was sealed in 1912 by then-mayor Johan Nygaard, the Independent reports.
                    an indepth scrutiny would be interesting ... newspaper titles / uv for hidden writings etc...
                    "I don't sit here with expectations that the world will be turned on its head because of the contents of the package," he said.
                    But he refused to rule out the possibility of there being "something sensational that will give us a proper 'a-ha' experience".
                    • Fighters bulldoze Sufi mosque in central Tripoli | Reuters
                      (Reuters) - Attackers bulldozed a mosque containing Sufi Muslim graves in the center of Tripoli in broad daylight on Saturday, in what appeared to be Libya's most blatant sectarian attack since the overthrow of Muammar Gaddafi.
                      Wahhabi - Wikipedia, the free encyclopedia
                      now let me present you with a word ... and let's see how it works
                      SHTHUGERNUNUH on these fools and their associates .... see the seven sisters
                      and now we wait .:: Kenneth Bager - Fragment Eight (The Sound of Swing) ::. - YouTube
                      from : http://www.energeticforum.com/206400-post2985.html
                      you know the Chaldean Goggles are quite fun to use
                      One Dollor Bill
                      just a thought
                      • side note:
                        if you play Harmonic Math with the 4*4 Sagrada Familia Magic Square .... you get :
                        1 5 5 4 = 69
                        2 7 6 9 = 96
                        8 1 1 5 = 96
                        4 2 3 6 = 69
                        and the Melancholy Magic Square :
                        7 3 2 4 = 16
                        5 1 2 8 = 61
                        9 6 7 3 = 61
                        4 6 5 1 = 16
                        and Magic Square of the Sun
                        6 5 3 7 8 1 = 57 = HM 3
                        7 2 9 1 8 3 = 93 = HM 3
                        1 5 7 6 5 6 = 48 = HM 3
                        9 2 4 3 8 4 = 66 = HM 3
                        7 2 1 9 8 3 = 12 = HM 3
                        9 5 6 4 2 4 = 21 = HM 3
                        let's try Venus :
                        4 2 7 5 1 8 4 = 31 ( 13 in reverse )
                        5 5 3 8 6 2 2 = 31
                        3 6 6 4 9 9 3 = 40
                        4 4 7 7 7 1 1 = 31
                        2 5 5 1 8 8 2 = 31
                        3 3 8 6 2 9 9 = 40
                        1 6 4 9 7 3 1 = 31
                        Four is it in qualities,
                        shining in each of the planes of existence,
                        but thirteen in one ,
                        the mystical number.
                        Based on the qualities of man are the Brothers:
                        each shall direct the unfoldment of being,
                        each shall channels be of the Great One.
                        • Link found between cold European winters and solar activity
                          Scientists have long suspected that the Sun's 11-year cycle influences climate of certain regions on Earth. Yet records of average, seasonal temperatures do not date back far enough to confirm any patterns. Now, armed with a unique proxy, an international team of researchers show that unusually cold winters in Central Europe are related to low solar activity -- when sunspot numbers are minimal. The freezing of Germany's largest river, the Rhine, is the key.
                          I love the following info because it is scalable ( fractal ) if you pay attention to the language used by the MSM / Politicians etc.... as if they are living in a bubble of complete illusion they build themselves ( the best way to lie is to believe in it .... it is also the source of its downfall )
                          any Strategist will tell you locking oneself in a castle is the best way to lose a war (even spiritual ) as you submit yourself to a Long Siege
                          Rolling Stones-Time Is On My Side - YouTube
                          Language, emotion and well-being explored
                          as within so without
                          think on these ongoing themes war on terrorism / war on drug / war on tv ( very Military wordings )
                          Our memory for events is influenced by the language we use. When we talk about a past occurrence, we can describe it as ongoing (I was running) or already completed (I ran). To investigate whether using these different wordings might affect our mood and overall happiness, Will Hart of the University of Alabama conducted four experiments in which participants either recalled or experienced a positive, negative, or neutral event. They found that people who described a positive event with words that suggested it was ongoing felt more positive. And when they described a negative event in the same way, they felt more negative.
                          • from: http://www.energeticforum.com/psychi...tml#post192807
                            love this story ............... reposting it
                            A nice story for you ..... about Water
                            Author: Lu Zhen
                            Confucius
                            Confucius said, ( it just is )
                            from: http://www.energeticforum.com/psychi...antenna-5.html
                            The possession of Knowledge, unless accompanied by a manifestation and expression in Action, is like the hoarding of precious metals-a vain and foolish thing. Knowledge, like Wealth, is intended for Use. The Law of Use is Universal, and he who violates it suffers by reason of his conflict with natural forces."
                            flows, although sometimes in low places and sometimes in high places justice
                            I have seen many rivers but never noticed that water has so many great virtues, which could be called neglecting while watching, having eyes yet not seeing, and for this, I truly feel ashamed.
                            A philosopher in China said,
                            The Dao School says, , the earth follows heaven, heaven follows the Dao, and the Dao follows what is natural a Great Master
                            • Hurricane Weather Model or Hurricane Wave Guide?
                              MonsieurM,
                              While checking weather underground for the latest hurricane Isaac weather, this particular hurricane proposed track (weather model) caught my attention:
                              Looks like they are doing some sort of weather modelling wave guide on the newly formed low off the coast of Africa and directing it to the USA?
                              IndianaBoys
                              • Hey IndianaBoys .... good to read you
                                there is a map that has been recently published giving you the track of all the Hurricanes for the past 150 years ....
                                IDV User Experience John Nelson Puts Together Map of Hurricanes and Tropic Storms Since 1851 | TheBlaze.com
                                it is a bit hard to see the US on this map but surely there is one with bigger resolution on the net
                                ---------------------- on a side note
                                crop circle update:
                                linking it to :
                                and also Hackpen Hill (3), nr Broad Hinton. Wiltshire. Reported 26th August.
                                ISIS = 13 13
                                ps: weirdly ... lately had the same feeling before a solar flare ... but stronger ... and checked no big solar flare lately
