  • Martineau [1] first pointed out the Golden Mean relationships between the outermost planets
    This is incredible, but it is only the beginning of the truly astounding. As Martineau [1] observed, not only does Earth have a Golden Mean connection to the planet furthermost from Earth in the direction of the Sun, but Earth also has a similar connection to Saturn, the visible planet furthermost from the Earth in the direction away from the Sun
    Signs and symbols -Confucius.
      The key in this regard [pardon the pun] is that Music is basically about ratios, frequencies (geometrical sine waves), and timing (a very mathematical kind of thingamagig). There is also a strong geometrical connection, in that, if one takes the unique 3-4-5 right triangle (with sides of 3, 4, and 5 equal units -- the only triangular shape utilizing a combination of single digit whole numbers which result in one angle of the triangle equaling 90 degrees -- however, larger numbers such as 5, 12, and 13 also work), and strings a continuous fine wire to each of the three points of the triangle, it is then possible to tune one of the sides to a particular note, and have the other two sides be in a tuned harmony. The three sides of the triangle form a series of tones that are equivalent to the first three strings of a tuned guitar. (One might also note that geometrically, one only has to tune one side of the triangle, while the guitar requires all three strings to be individually tuned!)
      • Rules of Harmonics
        The mathematics of the grid can be called harmonic math, as the entire system is harmonic in nature. The rules to understanding this harmonic system are as follows:
        1. Zeros to the left or right of the decimal point are insignificant.
        2. The system is based on 6 and 10.
        Looking at some examples for each of these rules will illustrate their significance.
        Example: 144000 nautical miles/grid sec is the maximum speed of light at the equator. Examining 144000, we find the following:
        144000 is harmonically equivalent to 144, 14.4, 1.44, and .000144.
        144 x 1000 = 144000
        14.4 x 10 = 144
        1.44 x 10 = 14.4
        .000144 x 10000 = 1.44
        Example: Let's examine the coordinate 14.4 N, 144 W.
        Both the latitude and longitude are harmonically
        equal to the speed of light 144000.
        14.4 N) 14.4 x 10000 = 144000
        144 W) 144 x 1000 = 144000
        Example: Let's examine the coordinate 86.4 S, 2.4 E.
        Again both the latitude and longitude are
        harmonically equal to the speed of light 144000.
        86.4 S) 86.4/6 = 14.4, and 14.4 x 10000 = 144000
        2.4 E) 2.4 x 6 = 14.4, and 14.4 x 10000 = 144000
        These examples were chosen for their simplicity. Usually the analysis of a coordinate is not as straightforward.
        ------------- other example posted earlier: http://www.energeticforum.com/renewa...netism-35.html
        Principle of correspondence
        and probably that is why Tesla used to weight his coils too, it is much easier than finding 5.914441183 feet
        look what i found you too are related to Light speed
        More importantly, at this higher concentration of salt the DNA returned to near its original length with a final measured indicating complete dissociation of Rad51.
        side note: from this post: http://www.energeticforum.com/163380-post1021.html
        Edgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
        "All matter is crystalic in nature" -- W.Russell.
        appear linked to the fractal arrangements of seemingly random oxygen atoms....
        ..., especially not in relation to the behavior of individual electrons, which exist at a scale thousands of times smaller. The findings, published Aug. 12 in Nature, are a physics equivalent of discovering a link between two utterly separate dimensions.
        and....
        Principle of correspondence:
        Originally posted by clueless View Post
        That from a 2002 article. Unlike so many other promising breakthroughs this is one that has been widely implemented.
        To further quote from the article: "The innovation, called Fractal Structure Circuit(TM) (FSC), uses fractalized conductor paths to replace the capacitors, inductors, and resistors in "RLC" circuits."
        And another quote: ""Virtually every electronic device uses coils and capacitors to form RLC circuits. These discrete components are arranged by tried and true rules to get the circuit to perform as needed. What we've done is ask: can a fractal pattern, with its self-capacitance and self-inductance, be used to eliminate components and still get the equivalent RLC circuit? We've found that the answer is yes; and in most uses, especially at microwave frequencies, all components can be replaced by conductive fractal patterns or 3D structures."
        And one more blurb from that article: " Looking at the Fractal Structured Circuit(TM) one sees, for example, a beautiful etched copper pattern replacing the usual traces connecting button or canned shaped capacitors and coils (or their SMT counterparts). "
        Here is the link to that article.
        Fractal Antenna Systems, Inc.
        Apparently it is in wide use in cell phones, their antennas and some microwave circuits.
        People are making homemade fractal HD antennas using coat hangers as one instance of using a common material.
        I think this feature; fractuals should be used in some builds to take advantage of a wideband of frequencies and resonance. Maybe it will be useful in the Muller/Romerouk build.
        For those that be interested google fractal circuits and fractal antennas.
        I do not have the resources/space/knowledge to do any builds at the moment but I am curious enough to verify if a HD antenna can be made simply using fractals and common materials.
        Any way something to consider.
        -RG signing off
        in other words:
        Fractal Structure Circuit = R L C circuit (works both ways )
        Let's not forget
        fractal property of nature
        Patterns of Visual Math - Fractals in Nature
        Fractal in Human Body
        Applications of Fractals - Human Body
          alpha_and_beta quartz
          both alpha quartz and dna are coaxial helices
          ------------Now apply the above infos to the following
          RF coils, helical resonators and voltage magnification by coherent spatial modes
          structured water :from http://www.energeticforum.com/renewa...tml#post166832
          For example sound in water medium would need to be at 72.36Hz to achieve the same wavelength as radiowaves at 13.56MHz.
          It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
          Luc MONTAGNIER DNA Teleportation
          A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
          According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
          Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
          note: looks to me that a zone of activation was created then the dna transfer was accomplished
          and also the weak electromagnetic field of 7Hz used is actually close to Schumann resonances:
          let's not forget the use of quartz test tube (maybe )
          The Schumann resonances (SR) are a set of spectrum peaks in the extremely low frequency (ELF) portion of the Earth's electromagnetic field spectrum. Schumann resonances are global electromagnetic resonances, excited by lightning discharges in the cavity formed by the Earth's surface and the ionosphere....
          ....as distinct peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8, 27.3 and 33.8 Hz.
          • Emerald Tablet of Hermes
            From Fulcanelli (translated from the French by Sieveking)
            1) This is the truth, the whole truth and nothing but the truth:-
            2) As below, so above; and as above so below. With this knowledge alone you may work miracles.
            3) And since all things exist in and eminate from the ONE Who is the ultimate Cause, so all things are born after their kind from this ONE.
            4) The Sun is the father, the Moon the mother;
            5) the wind carried it in his belly. Earth is its nurse and its guardian.
            6) It is the Father of all things,
            6a) the eternal Will is contained in it.
            7) Here, on earth, its strength, its power remain one and undivded.
            7a) Earth must be separated from fire, the subtle from the dense, gently with unremitting care.
            8) It arises from the earth and descends from heaven; it gathers to itself the strength of things above and things below.
            9) By means of this one thing all the glory of the world shall be yours and all obscurity flee from you.
            10) It is power, strong with the strength of all power, for it will penetrate all mysteries and dispel all ignorance.
            11a) By it the world was created.
            12) From it are born manifold wonders, the means to achieving which are here given
            13) It is for this reason that I am called Hermes Trismegistus; for I possess the three essentials of the philosophy of the universe.
            14) This is is the sum total of the work of the Sun.
            • Nature loves courageTerence McKenna
              Seek your own Truth...The more Telesti there are...the faster change will come..you feel it....
              You are by nature: a Telestis "one who is aimed"
              Telestis: Greek word from Telos: goal, aim. they were Gaian teologists. totally illuminated by their practice of ecstatic contact with nature. The best definition: one who is aimed. If you are aimed by Gaia, you will go where she sends her arrow.
              • note: look at your fingerprints; what do you see
                Principle of Mentalism: The Universe is all Wave
                • It is all a matter of Perspective (plane) Principle of correspondence:
                  remember the Universe is Harmonically Fractal and learn to use it to your advantage
                  Alexander - Truth - YouTube
                  • Dr. Hildy: The Eye of Horus from Egypt to Quantum Dots, 1st Hour - YouTube
                    1st hour: The writings of Manly P. Hall on The Soul in Egyptian Metaphysics and the Book of the Dead; The Pineal Gland: The Eye of God; and Melchizedek and the Mystery of Fire
                    Manly Palmer Hall - Wikipedia, the free encyclopedia
                    • Principle of Correspondence
                      Magneto-optic effect - Wikipedia, the free encyclopedia
                      A magneto-optic effect is any one of a number of phenomena in which an electromagnetic wave propagates through a medium that has been altered by the presence of a quasistatic magnetic field. In such a material, which is also called gyrotropic or gyromagnetic, left- and right-rotating elliptical polarizations can propagate at different speeds, leading to a number of important phenomena. When light is transmitted through a layer of magneto-optic material, the result is called the Faraday effect: the plane of polarization can be rotated, forming a Faraday rotator. The results of reflection from a magneto-optic material are known as the magneto-optic Kerr effect (not to be confused with the nonlinear Kerr effect).
                      While searching magneto optic materials, i found this:
                      Magneto-optical characteristics of human sper... [J Biophotonics. 2008] - PubMed - NCBI
                      Magneto-optical characteristics of human sperms: normal and deformed.
                      In this study we report on magnetic orientation of human sperms. Samples were taken from 17 donors. Normal human sperms became oriented with their long axis perpendicular to the magnetic field (1 T maximum). Total orientation was achieved with magnetic field of about 1 T, while for abnormal sperms the magnetic behavior was different. The dependence of the measured degree of orientation on the intensity of the magnetic field was in good agreement with the theoretical equation for the magnetic orientation of diamagnetic substances. As a result of a numerical analysis based on the equation, the anisotropic diamagnetic susceptibility of normal sperm was found to be Delta(chi) = 8 x 10(-20) J/T(2). The degree of orientation was influenced by the alterations in the shape of the head, body or the tail. It has been suggested that the DNA in the sperm head retain the strong magnetic anisotropy to counterbalance the magnetic anisotropy retained by flagellum microtubules. Recent studies demonstrated a well-defined nuclear architecture in human sperm nucleus, where the head morphology has significant correlation with sperm chromatin structure assay SCSA. Then, as the methods to evaluate SCSA can be difficult and expensive our simple magnetic orientation technique can be an alternative to diagnose alteration in DNA.
                      also...remember Walter Russell periodic Table:
                      The image below is taken from the book Helical Helix : Solar System a Dynamic Process by Dr. Pallathadka Keshava Bhat (comments added).
                      here is the picture
                      • Watch the world events beat to the rhythm of the sun.....
                        Slackwax - Close to my fire - YouTube
                        listen to it, the lyrics are aimed at you and your soul
                        • from: http://www.bibliotecapleyades.net/ar...ilosophers.pdf
                          This important point, where the elements and the principles of the highest knowledge are
                          concentrated, could not be search nor encountered in life, as life is within is, as it radiates
                          around us, as it is familiar to us and as it suffices to know how to observe it in order to
                          grasp its different manifestations. It is in death that we can recognize it, in this invisible
                          domain of pure spirituality, where the soul, liberated from its bonds, takes refuge at the
                          end of its earthy stay; it is in nothingness, this mysterious nothing which contains
                          everything, the absence where all presence reigns, that it is proper to search for the
                          causes, the multiple effects which life is showing us.
                          listen to the following, you surely will enjoy it
                          Jenny Wilson - Anchor made of gold - YouTube
                          Lilly Wood and The Prick - No no (kids) | LeTransistor.com - YouTube
                          COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
                          An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
                          . a harmonic cascade effect
                          • Tuning out: How brains benefit from meditation
                            Experienced meditators seem to be able switch off areas of the brain associated with daydreaming as well as psychiatric disorders such as autism and schizophrenia, according to a new brain imaging study by Yale researchers.
                            Meditation's ability to help people stay focused on the moment has been associated with increased happiness levels, said Judson A. Brewer, assistant professor of psychiatry and lead author of the study published the week of Nov. 21 in the Proceedings of the National Academy of Sciences. Understanding how meditation works will aid investigation into a host of diseases, he said.
                            • a necessary repost http://www.energeticforum.com/renewa...netism-28.html
                              Originally posted by petar113507 View Post
                              I agree. It's time we understood our souls -- our body's recording system. It also relates to the "golden tractate" in that the substance/form which we are looking to create/produce, seems to be like quite the turbo supplement for our soul's unfolding....
                              Further clues that it is about the noble gasses somehow. I don't know how exactly, but they keep popping up everywhere that I look. I can only share what I know -- I hope this makes things "click" for you.
                              Russell's law of crystalization embodying a different facet of its "fractal" meaning:
                              I wanted to better understand this, and so I seek. I am seeking, and so I am finding it. I've also been curious as to what russell meant by thinking in light -- being able to think in the "universal language".
                              I've been recalling when I was younger -- learning to use both sides of our body is not remarkably difficult to learn how to use in conjunction. It requires a little bit of co-ordination.
                              What the heck does that even mean? I've almost forgotten how I got co-ordinated in this body.
                              I remember seeing a baby oogling at his hands, and as he marveled at them -- how they worked -- how he could seemingly only have one side flexing according to his desire at once. Eventually he learned how to move both, of course -- but I'd actually forgotten what it was like to be dumbfounded and in awe at how my hands worked!
                              If our bodies are electric puppets -- the tesla coil analogy brought up the idea
                              How big is that field? I mean -- if what I regard as "me" as outside my body....
                              How was that baby moving its arms? It was learning -- adapting -- localizing more acute records of how his "mind" was piloting his body. And how does a baby moving its body have "harmony"? Isn't harmony a superimpositon of different frequencies?
                              And then Russell, again...
                              Oh, how you tickle my brain into remembering old, and new things....
                              And so -- our piloting mechanism is above our bodies. When concentrate that "field" inside our bodies, we are "awake". The abillity of that field to command our bodies in different ways is a matter of very precise, fine signaling.
                              And so, I look to the sky. Many "common sayings" hold a lot of truth to them, if you consider them in this light.
                              "that idea came out of the blue" (Think -- where did that idea's form ACTUALLY come from? Someone was probably being pretty honest in their sensing of how the idea came to them.... )
                              "they were giving me weird vibes" (How can you feel the "vibrations" piloting their decision making mechanism -- by interference with "your" body's piloting field)
                              "You seem kinda spacey" (Your awareness is not concentrated to a sufficient density in your body for you to be "present")
                              When I saw the Russell picture -- I was immedeately reminded of the concept of the "unconcious mind". I don't know about it being unconscious at all -- I think that's a bad word. Perhaps "Inner self" is a better word for the all-intelligent taproot of consciousness extended to each of us. Regardless, I have asked "it" to give me positive signals (tingles down my spine -- rushes of energy) when it detects something that is useful to me.
                              (I've learned It likes to work with you -- as it has been working with you whether you like it or not.... Might as well try to speak the same language as it)
                              So, I asked "myself" what it meant when you "decentrate" your awareness out of your body when you meditate -- I got a simple picture. That field would retract itself from your sensed body, much like a pilot can step out of the cockpit of an airplane....
                              Ever seen anyone fall unconscious?
                              Ever done it yourself?
                              Did you notice any colors upon the exiting of your body or a "flash" before?
                              I've been thinking about harmony -- and music -- how what everything that we do is also apart of "the music of the spheres" (keeley) It's pretty wild. It makes me see how everything is really beautiful...
                              Think of the incredible tenuity which your consciousness (that feild) posesses to be able to relax back into a "0" or "null" form (to have a blank mind, or still mind), and then spring into a form, to assume an image in your imagination -- then back to rest again. That happening every time your neurons fire and form a thought -- is pretty amazing.
                              It's your own cosmic themesong, playing right into your antennae...
                              I find myself writing another long winded post -- So I'll wind around to some of the points I wanted to originally go over...
                              Why is "all mankind one"??
                              Well, our senses might not have grasped it yet -- but those sparks above us are definitely apart of our piloting mechanism. Are we really selfish enough to think that ALL those sparks in the sky are JUST for a SINGLE human? That's insanity to think that way.
                              If you can see the sparks -- I'll show you subjectively. If not, bear with me for a moment... The range within which we can see those "sparks" also somehow has to do with internal voltage pressure -- like the anti gravity conditioned field/chemically accelerated reaction zone -- "making invisible light, visible".
                              If you can focus real close to your body -- maybe seeing the white sparks within five feet of your hands -- try to jerk your fingers around a little bit in abrupt impulses.
                              (Hint: It's easy to see them up close on a cloudy day, when they're hiding from the sun)
                              Relax your muscles in between each impulse -- you might be able to see that your muscular twitches make the white sparks "dance" about quite well. If you flex different muscles hard enough -- you can get them to dance above their normal "agitation movement rate" by your "invisible body" -- its signaling intereference from quite a distance away....
                              The sky is the limit...
                              Dually noted -- if you can make the sparks dance around -- isn't water attracted to the sparks (or the sparks to the water?)?
                              If you've found you can move them -- you might be able to move water with that "energy", or with those "sparks".....
                              I figure, everyone should be able to -- as soon as they realize their body made up of a large percentage water.... With that in mind -- how do you already translate an impulse out of your body, into a body movement?
                              You'd have to move the water outside your body in the same way you'd move your body itself -- same type of impulse from your consciousness.
                              "As above, so below -- As within, so without"
                              Listening to me describe this, Reminds me of hearing about "fly ash".
                                around us,
                                You have experienced this if you ever met a pregnant Woman, you have felt the glow /aura
                                what do you think that is
