ELFE-electromagnetic field engine
  • ELFE-electromagnetic field engine
    2 photos of ELFE, this I'm assebled in this year.
    I wanted one go on intended for me road.
    I look like essence from the other world, but this error.
    Very misterious device. What does it do? And what you observe?
      based on her signature she might not know a whole lot of english.
        12 coils with 3-whorl, suply under pulsed current, 600 Hz 180V, this device change mass -2,7 gram.
          "Speaking English"
          Persian Princess knows enough English for most conversations and if she does not understand some terminology, she'll ask me and I'll clarify it. Also if what she replies is not clear, I can better translate it for the forum.
          -Madame Dry Ice-
            Thank you . Very interesting . Have you every read "lifter project", Thomas Brown or Victor Grebenikov?
            In lifter the ion wind generated from HV pole is said to work even in vacuum. And VG mention that spesific geometry can have antigravity movement when powered.
            From the shape, your look like lifter with many pole. And the hexagonal shape is like what VG suggest for healing energy radiation.
            Have you ever try to power it with sparkless 10KV to 40KV?
              Yes I long ago read all these subject.
              But my device to work without electrostatics, in base here control to orgon.
                I see, interesting .
                So the internal of those geometry is metal with wood outside (orgone accumulator)?
                  Psychic & Paranormal??
                  Why are you posting this under, Psychic and Paranormal?
                  You might get better discussion if you post in a more appropriate place on the forum.
                    So it reduces weight? Counters gravity?
                    Do you have data or is it still in the making?
                      The Body inwardly empty, material-thick paperboard.
                      Yes weight reduction.
                      I think this team it is necessary displacement in more suitable section, request to admin.
                        Just recently I found that HV DC produce thrust and wind. Output voltage beyond 2000V at around that frequency.
                        YouTube - An attemp to capture ion wind
                        YouTube - Playing with bare wire
                        Would your device produce ion wind too? What happen to candle fire if you place the candle next to active device?
                        Thanks, interesting .
