Compensatory Magnetic Oscillator
  • Compensatory Magnetic Oscillator
    CMOHome
    Ash
    MySafetyShield.com | Your 1st Line Of Defense
      That basically describing Karl Welz orgonite.
      Scientific research has shown that there is a connection between the electromagnetic radiation emitted by LCD-Flatscreens and laptops resulting in complaints such as:
      Insomnia
      Headache and migraine
      High blood pressure
      Restlessness, stress
      Loss of concentration, productivity, etc.
      Muscle complaints
      Symptoms of soreness, aching joints
      Dizziness
      Allergies
      Hyperactivity
      Chronic fatigue
      Those consistently match the list of the bad effect of male energy overdose mentioned on a book exist 150 years ago, by Karl Reichen bach. Some of that are experienced by my wife that I can solve with either radiant sleeping aid and cemenite.
      The book is written before the existance of radio or electronics. Surely at that time people who suffer that effect do not blame it to electronic or wifi. I realy really hope people are not wrong to blame "high frequency" or "high voltage".
      Everyone suffer the same thing should try cemenite, I think you can make it for $2. Or if you have money, around 10$, build radiant circuit or stingo, and use it as radiant sleeping aid.
      I expect cemenite to have left scale reading on your orgone meter ashtweth.
      Our C.M.O. Solution For Radiation
      Over 10 years of comprehensive research and testing by some of the world's leading scientists and corporations finally paid off. An innovative device was developed to effectively protect against the many harmful bio effects of electromagnetic radiation. This patented device is known as a Compensatory Magnetic Oscillator or 'C.M.O.' for short. When used as directed, items such as cellphones, televisions, computers and many other common household and office electronic appliances and devices are made safer to operate.
      Karl Welz introduce orgonite more than ten years ago.
      I fond the site to be less credibel to also offer phone jammer:
      If they consider cellphone to produce high level of dangerous radiation, they sure are insane to offer device that can over power cellphone signal to prevent them from working.
      My conclusion is CMO solution is just a copy of Karl Welz orgonite. The effect is real, I see some result with cemenit. If you make it yourself or buy orgonite make sure you don't try the Don Croft version before you do complete verification to its effect. Don Croft style orgonite can produce some side effect because of the inclusion of crystal.
      Make sure you test it on yourself before you give it to sick people. Because if built wrong, it can produce the exact problem you are trying to solve. Don't underestimate this energy, it can kill people. If you often had constant headache, try.
        Sucahyo "Radiant Sleeping Aid" ???
        For the radiant sleeping aid you suggest, what type contacts, or antenna, or
        coil, or other device do you use to radiate the energy from the source ? Also
        where do you position them ? Near the bed or just in the room somewhere ?
        FRC
          Originally posted by FRC View Post
          For the radiant sleeping aid you suggest, what type contacts, or antenna, or coil, or other device do you use to radiate the energy from the source ? Also where do you position them ? Near the bed or just in the room somewhere ?
          The thread:
          I consider any radiant circuit can be used, although I now think bedini cole modification to my original may have better result. negative output to bed frame metal, positive output to non grounded water.
          Try to get more than 40V at the output. It is important that the positive output to not connected to ground. With non grounded water the output voltage is twice higher.
          Godfrey and I happen to put the circuit near the bed.
          This solution more or less similar to lee crock MWO. Although I originally try to replicate tesla electric sauna.
            Thankyou
            Thankyou for the very detailed reply and circuit Sucahyo !
            FRC
