Hi all.
Some days ago a friend introduced me to a simple water treating technology that can separate water into acidic and alkaline groups, he found it in a book about natural healing methods. The acidic is the so called dead water and the alkaline water is supposed to be the living water. If you are interested in this, then you absolutely need to read this info:
Alkaline Water and ORP Explained
it is absolutely a must read, it explains how and why your body is constantly being in acidic PH levels and how that affects your health. This is very important info IMHO as it might hold the key to curing all diseases. Also it correlates with several OU water technologies out there. I uploaded a diagram of this simple system. You need rectified mains power and two stainless steel electrodes, you can use forks if nothing else is at hand. You need to insulate the positive electrode from the rest of the water using some thigh linnen fabric bag or something similar that will let the current pass, but wont let the two waters mix together. I used a plastic cup and drilled many holes on the perimeter, then I wrapped the cup with paper towel and several layers of thin linnen rope - works great. When you apply the power, some bubbling action will be seen. After some 15 minutes the water should be ready, the positive electrode water will be yellowish or even brown and with PH as low as 1, it might have some chlorine smell to it. The other water can become milky, that stuff needs to be filtered out, that is calcium compound which no longer is dissolved in the water. This water will have PH up to 13, the longer you run the thing the higher the difference. This is then used to drink, several cups a day. So according to the article above we now have a water that is saturated with negative charged OH ions that have a free electron to donate, since a healthy body has everything in balance, such water wont do any harm to it, but it will destroy pathogens. This should be a great way to rejuvenate your body without using any chemicals. I am starting to use it daily now and will report the results, so far everything looks good. The dead water shouldn't be thrown away as it also has some good properties, it is a great disinfectant, you can use it to wash any wounds and they will heal quickly. The dead water should also be used in the mornings to rinse the mouth, is good for the teeth. Also such a procedure removes teeth pains. It is good for the skin on the face to be washed with the dead water first and then with the living water, it makes it smoother and softer. The dead water is also good for headache, drink a half glass of it and the headache will be gone in 30 minutes. And the list goes on. To get back to perfect health you need to rinse your mouth with the dead water in mornings and evenings after meals and right after that drink a half glass of living water.
The living water keeps its charge about 12-24hours since it is negatively charged and almost everything around us emit positive ions.
So does this remind you of something?
What about the miracle mineral? That is a chlorine compound that when activised makes a molecule that has a free electron to donate and supposedly cures all diseases. The same can be made with water and without any chemicals. Also do you remember Joecell? The cells also needed to be charged for several days and retained their charge only for a limited time. Joe talked about charging his cells with negative energy, but no one really understood what he meant by this. I am certain that this is exactly what he meant. Remember Joes secret power supply for precharging water before putting it into the cell? No secrets in that anymore, he had a variac with a rectifier on the output, the positive of the rectifier was dumped in the ground and the negative of the rectifier went to the cell. Well it is now obvious what he did and why so many, including me, have failed. In order to make the joecell work you need to get the water as negatively charged as possible. This should be also super good for the health. So I encourage everyone to experiment with this.
Jetijs
Jetijs
, but if you get a good water, like from a well or spring, either the acidic or alkaline portions of the treated water will be tasteful and with no aftertaste. That is a good water. Very interesting stuff. My goal now is to get a ORP meter that measures water charge in milivolts. Then I will make several experiments to find out how water vortexing, magnetic fields, negative HV affects the charge and which method produces the most negative charge. Will see what that water does. Some russian scientists claim that such a water, mixed with few drops of diesel, will assume the diesel properties and burn the same as diesel, but the effect will last only 12-24 hours. I have to verify this. Also it would be interesting to use such water in a hho cell. Should work without electrolyte since it is already very alkaline and conductive. The best thing about this is that the level of water charge can be simply measured with an ORP meter and we don't have to rely on feelings of energy flows and similar stuff, like all the mess with charging joecells. Will inform you about my results.
