Warning, contain highly subjective information
There are many website offering electronic sleeping aid such as:
'ZED-TIME' ELECTRONIC SLEEPING AID
What being offered by those website usually work with audible frequency or electrocution, usually placed at ear.
What I offer is different, I use the principle mentioned by people who research radiant energy. The device works based on theory proposed by Nikola Tesla (as written by Gerry Vasillatos) and Baron Karl Von Reichenbach. Switched coil can produce radiant energy and there are two type of radiant energy. Each radiant energy have different effect on people.
I use the switched coil as pump. A pump to force the radiant energy to go to only one direction.
Here is the circuit:
To prevent wrong wiring, here is mine, I use it for motor too
Edit:
In my test earth ground have no effect. An isolated water bucket would. You would notice the effect if the voltage is high. Connecting the radiant positive to ground do not produce higher voltage.
In order to get the same result, I can only only suggest exact replication. The components are:
- 24V (or 12V CT) to 240V 1000mA
- TIP31C transistor
- TIP32C transistor
- 10K variable resistor
- 1N4007 diode, the one on the right
- FR304 diode or other 4 amp diode, for radiant recovery, the one on the left
- 3V battery
- analog voltmeter to measure voltage
- may have to short battery negative to coil negative (bypassing transistor) to activate the circuit
- you know the circuit is running if you see voltage in voltmeter
I make this device in a desperate attempt to help my wife to sleep at night.
I use the circuit as zapper first. While it can help her sleep a little, prolonged use is uncomfortable since human body act as capacitor and the output voltage raise with time to more than 50V. It also leave some serious numbing effect.
Then I remember Paulo Correa article that mention that Tesla Coil produce orgone. Then I link it with BKVR about the influence of orgone to sleep behaviour. To get better sleep people must not accumulate too much positive odyle or deadly orgone (Wilhelm Reich). In order to reduce this accumulation, adding negative odyle or life orgone can help. Such as cool water, downward passing of right hand or magnet north, etc.
I also remember that BKVR mention electrical positive produce negative odyle. Then I proceed to attaching the positive radiant output to my wife leg and the negative to mine. It did nothing. Then I reverse it with negative radiant output (which is also connected to battery positive). After a while my wife get sleepy and finally get a good sleep. I stay awake though, lol, I think that the radiant circuit must somehow transfer my wife positive odyle to me.
The next day I connect the positive radiant output to a wire that have end submerge in a bucket of water. Remembering about cloud buster wire end must be submerge in flowing river. The negative is attached to my wifes leg. The device still work and my wife can sleep better too.
The next day I connect the negative radiant output to the steel of my bed. It seems to work too and this time everyone get sleepy upon entering the room lol.
My version draw 20mA while running. It will run all night outputting around 40V using two 1000mAh nicad. Use the variable resistor to adjust power. You may notice a jump of output voltage when the output is attached to people.
If you have exhaust the effort to get better sleep, give this device a try. At least it won't disturb your sleep. Or if you find it useless as sleeping aid you still get yourself a charger or a zapper
I can not recommend other radiant oscillator for use as sleeping aid (many people in this forum already have one) because many reported ill effect near their circuit and more importantly my circuit do not behave the same as other radiant circuit.
If you find this circuit useful while a donation would be great any comment would be very appreciated
Edit:
- TIP31C transistor
- TIP32C transistor
- 3V battery
.I can not recommend other radiant oscillator for use as sleeping aid (many people in this forum already have one) because many reported ill effect near their circuit and more importantly my circuit do not behave the same as other radiant circuit.
