FIR Saunas for detoxing?
  • FIR Saunas for detoxing?
    Has anyone used one?
    I've been doing a little reading about it and it sounds very interesting. It also seems to be an easy and non-invasive way of doing detox.
    I've also read a theory that suggests that difficulty in losing weight is due to toxins being stored in fat. The fat is actually keeping the toxins from doing more damage to your body. If you detox, then the fat can be released. That's a very pared down version of the theory, but I think you get the idea.
    Just curious if anyone here has any experience with the FIR saunas.
    Ann
    Paths To Your Success
    IR sauna
    I own one. It is one of the best health inventions ever. Absolutely priceless.
      hi,
      what is an IR/FIR saunas? what does IR or FIR stand for? and what does it do?
      Thanks...Adrienne
      Matrix Energetics Sessions-Private message me
      www.paths-makeithappen.com
      http://www.divineopenings.com/cmd.php?af=1060186
        ir & fir sauna
        Hi Adrienne,
        The IR is infrared and FIR is far-infrared from the 800nm (800 billionths of a meter wavelength - nanometers) and longer. It is basically invisible red light, which is infrared heat.
        In these saunas you will sweat 2-3 times MORE than a hot steam sauna at that is at 80 degrees cooler or more!
        A hot steam sauna isn't as healthy as it is cracked up to be. Your body is warmed like food in an oven. The air temp is heated and this slowly warms up the body. It takes a lot of energy to heat the environment that the person is in. The body is trying to ventilate the heat and does so by sweating out electrolytes and really there aren't much toxins in the sweat from this type of sauna that operates at about 200F and hotter.
        The infrared sauna can make you sweat 2-3 times more at only about 140F so much safer. The infrared penetrates up to about 1.5" (inches) deep and warms you from infrared penetration and NOT from having to heat the air around you.
        It can be below freezing and your hand will feel cold in the cold air but if the sun is shining, you can feel warmth on the hand. How can that be? The air the sunshine is coming thru is freezing cold but you feel warmth on your hand. The heat is produced AT your hand by the IR meaning that the heat that is generated on the Earth from the sun literally is produced locally and literally the heat is not leaving the sun itself...only the waves that will eventually stimulate heat when hitting something.
        Lots of toxins are released from infrared saunas since the deep tissues are warming up from the IR & FIR penetration.
        You can use one of these saunas for an hour a day every day for a month and you probably won't see but a $5 increase in your electric bill.
        I sold these in the past when I worked with a company selling devices for healing based on heat and light.
        These saunas can burn up to 1200-1500 calories per hour.
        Improves flexibility by up to 15% for many hours after getting out.
        Improves circulation, improves mobility in joints, relaxes tight muscles, and relieves pain.
        Gives a good cardiovascular workout without moving a muscle.
        Sherry Rogers MD uses these saunas quite extensively in her practice for environmental detoxification. I met her once at a medical conference in Vegas once with a MD I worked for and they went to the same medical school at different times. The sauna was the common interest.
        Here are her books:
          Sherry Rogers Infrared Sauna
          The Far- Infrared Sauna
          The secret of sweat.
          Clear Body Clear Mind SWEAT.
            Sherry Rogers Infrared Sauna 2
            FIRS, the Only Sauna Proven Safe for Elderly, Severe End Stage Heart Patients
            How is the Far Infrared Sauna Different?
            Circulation and the Journal of Cardiology, both respected cardiology journals, physicians at the famed Mayo Clinic use the worst classification of congestive heart failure patients to demonstrate the safety and therapeutic value of the far infrared sauna. They study used patients who were end-stage heart patients who were maximally medicated and unable to walk across the room without shortness of breath, unable to tolerate warm baths, much less tolerate a sauna.
            During the FIRS , no patient had dyspnea (shortness of breath), angina (chest pain) or arrhythmia ( irregular heartbeat), nor complained of excess heat. There were no side effects, something that never happens with drugs and surgery. Diastolic blood pressure ( the low number) decreased but the systolic pressure ( the top number) was unchanged. This means they did not get hypertensive, and in fact the work of the heart was lessened. Furthermore the stroke volume and ejection fraction increased, meaning the heart beat more efficiently with less effort.
            Contrast this with warm baths that caused an increase in systemic blood pressure and pulmonary vascular resistance. Warm baths, by raising blood pressure, cause more work for an already failing heart. And in a regular sauna, the arrhythmias increased 20%, whereas in the FIR sauna, arrhythmias decrease or disapproved entirely. Other cardiovascular improvements unique to the FIR sauna that would impress cardiologists include decreased pulmonary arterial and capillary wedge pressure as well as right atrial pressure, and in some cases disappearance of mitral regurgitation. The ECHO (echocardiogram) showed smaller left ventricular and left atrial dimensions, and epinephrine levels did not change, but norepinephrine increased.
            Because the far infrared sauna has so many physiologic benefits that improved cellular detoxification (without making the rest of the body toxic or sick in the process), no side effects were observed with the FIR sauna, even at 140F.
            In conclusion, the FIR sauna was extremely well tolerated and did the impossible. It improved the cardiac status of folks who were at the end of their therapeutic ropes. Even though medicine had nothing more to offer, congestive heart failure was reversed by the far infrared sauna.
            Excerpts taken from Dr. Sherry Rogers, MD Detoxify or Die Pages 191-213
              Sherry Rogers Detoxification
              The Simple Detox Cocktail Solution
              I strongly recommend everyone make the detox cocktail to have once or twice a day. It revs up both phases of detoxification.
              So for starters why not incorporate the detox cocktail into your daily regimen? If you get diarrhea from a teaspoon of Vitamin C powder, cut back to a half or a quarter of a teaspoon. When you do beneficial things for your body like the detox cocktail, it often has multiple other benefits. (pg 51) Vitamin C can protect against thyroid damage cause by environmental heavy metals. This is just one more reason why the daily detox cocktail is so important. (Pg 125)
              The detox cocktail protects the body in a wide range of ways. It revs up detoxification of environmental chemicals, guards against a heart attack or blood clot, and cleanses the gut, protects our genes, and boosts cancer killing cells. Pg 51
              Boosting the Rest of Your Detox System
              What else can you so to rev up the ability of your body to fight free radicals and detoxify their major cause, the environmental chemicals contained in our air, food and water? For starters, the detox cocktail, detox enema Lipoic Acid are great for boosting phase 1 of detoxification.
              The Detox Enema
              The main way the body gets rid of health-damaging and age-promoting chemicals is through the gut. Nutrients like Vitamin C can prepare and attachment site on the chemical for glutathione. The body makes a lot of glutathione that can hook onto this prepared site, making the toxin heavy and polar (electrically charged). This facilitates dragging the chemical out of the bloodstream, into the liver, then into the gallbladder and last into the intestines where it is flushed down the toilet.
              If you are constipated or the gut is not completely healthy, the nasty chemical that has been dragged into the gut attached to glutathione does not end up in the tank. Instead, the glutathione falls off the chemical and the chemical is now reabsorbed into the body, ready once again to do its damage.
              The phytonutrients in the organic coffee also go directly from the colon veins to the liver. In the liver they actually stimulate the syntheses of more glutathione along with release of detoxifying bile and glutathione. In other words, the detox enema supercharges your detoxification system. Pg 65
              Lipoic Acid
              Lipoic acid is called the universal antioxidant because it can quench nearly all free radicals. It also recycles antioxidants like vitamin C and E back to their useful forms.
              Glycine
              The simple daily detox cocktail can keep your body from stockpiling or accumulating so many chemicals. It does this by revving up phase 1 of detoxification with Vitamin C Powder and revving up phase 2 with glutathione. If you want to add even more power to your detox cocktail you can add Lipoic Acid. If you want to make you detox cocktail even more potent, add glycine.
              Glycine is a very simple amino acid, and it is also one of the three ingredients that the body uses to make its own glutathione. But just as the body hooks glutathione onto unwanted chemicals to help drag them out of the blood and into the stool, it uses glycine to help drag them out of the blood and into the urine. Pg 75
              One of the main ways that phthalates or plasticizers cause liver cancer is by damaging the chemistry of little organelles inside the cell. In molecular biochemistry this process is called peroxisome proliferation. The important thing is that glycine can prevent this. Furthermore, glycine can protect against cadmium toxicity. When you realize what a potent detoxifier it is, it probably comes as no surprise that it also protects the lungs against other types of toxins. If that were not enough, glycine has some other very unique properties like zapping sweet cravings, helping hyperactive kids and anxious adults with jangled nerves and even has improved schizophrenia, epilepsy, depression, learning disability and memory. It also helps people thwart hypoglycemia and fatigue.
              Warning
              Glutathione
              Researchers found that when they gave 500 rats- used for cancer research-glutathione before, during, or after the introduction of a carcinogen chemical, the rats did not develop cancer. Pg 185
              Excerpts taken from Dr. Sherry Rogers book Detoxify orDie
                I gotta get me one o' these!!
                Thanks, Aaron, for all that helpful information!
                I'm even more convinced, now, that I want (and need) one of these. I just wanted opinions from someone who wasn't selling them before making my decision.
                Looks like I need the book, Detox or Die, also.
                Thanks again, Aaron.
                Ann
                  Portal IR Sauna
                  Hi Aaron,
                  Would you comment on the effectiveness of the portal sauna, which is much less expensive, as opposed to the stationary unit?
                  Thanks for all the helpful info.
                  Peg
                  ZPoint Practitioner
                    Great idea, Peg!
                    Here's a link to the one that I'm interested in -
                    Portable FIR Sauna
                    This one has free shipping and is the best price I've found for portable saunas. I don't have room for a stationary one, so portable is the only way I can go.
                    Always appreciate your input, Aaron.
                    Ann
                      There's also quite a few on sale at ebay for even less! Just fyi.
                        infrared bulbs in the bathroom?
                        Aaron,
                        What about those red heat lamps for bathrooms? Does it do the same thing?
                        And how many milligrams glycine, lipoic acid, and vitamin C does one take for the detox cocktail?
                        Thanks for the info....
                          Revisiting this topic with a 'buyer beware'
                          After many long months waiting to be able to afford a Portable FIR Sauna, I ordered one on eBay that looked very similar to the one I linked to above. It arrived today and it was a BIG disappointment. I sat in it for 40 minutes at its highest 'power level' - '5' and it was barely warming me and certainly did not make me sweat. Fortunately for me, the seller is going to refund my money.
                          It is my understanding from Aaron's explanation and other reading I've done on the internet that FIR heat is like the heat of the sun. If I had spent 40 minutes in the sun I would have been sweating like a pig after just a couple of minutes. Didn't even come close in this sauna.
                          This experience has lead me to suspect that most of the 'portable' FIR saunas that are for sale in various places on the internet are not really FIR saunas. It seems to me that a true FIR sauna would not require a warm up time, but I could be wrong about that.
                          I'm going to do more research before purchasing another and I may have to wait till I can afford one of the wooden ones.
                          Just wanted to share my experience in case it might be helpful to anyone.
                          Ann
                          • #14
                            Another portable FIR sauna
                            Here's a link to the one sold by Tools for Wellness, watch out for the sticker price! Portable FIR Sauna
                            The website has plenty of photos, including some of the unit being knocked down for storage.
                            Ann-ticipatingSuccess, I'm grateful that you shared your experience. So glad you were able to get a refund!!
                            Aaron, is this a good unit? Where did you get yours?
                            Hugs to everyone that reads this post!
                            • #15
                              Originally posted by belle99 View Post
                              Aaron,
                              Hi Belle...I never saw this post!!
                              Some people have made saunas from these heat lamps but you have to really be careful...I think they can be quite a bit hotter.
                              You can make the ceramic infrared element type sauna in a closet, etc... by ordering infrared heating elements from Granger Electronics, etc...
                              I don't know the doses for those ingredients but if you search for
                              Dr. Sherry Rogers book Detoxify or Die
                              you might find the doses.
