Cancer Cause & Cure
  • Cancer Cause & Cure
    shakespirit@gmail.com
    I saw this
    http://www.moneytrendsresearch.com/scientists-cure-cancer-but-no-one-takes-notice/
      Refresh
      Alternative Cancer Treatments
      open source there
      I am not a cash cow for treatments, ASEA, or any thing else going, watch me show you i am not if any one challenges me on this
      Ashtweth
        Guys of Panacea you have done an amazing job in collecting all these cures for cancer on your webpage !!!
        Thank you very very much ! I'll send you a donation as soon as I get my payday. One day I might have a cancer and your data will save me from suffering and premature death
        Amazing, keep on the great work !
        Thank you so much !
        JT
          Thanks for the posts. Fungal origins of the Big C is as plausible as any I have read about. But then one has to add.... how come the body got compromised to the point where the fungus among us could take advantage?
          At least the fungal theory provides a possible starting point for treating cancer.
            Interesting article. I am familiar with Sutter General Hospital. There is evidence that certain toxins in the body lend a person more susceptible to getting cancer once exposed to such fungus. One big one is isopropyl alcohol or rubbing alcohol. It's not only in rubbing alcohol but many cosmetics and lotions.
            Ash do you have info on MMS (Jim Humble) on Panacea? It is one of the more powerful and inexpensive cures I have seen. It's one I think would be very beneficial for everyone to be aware of.
              Cancer a Redox Disease
              Whether it is toxins, lack of oxygen, fungus, etc... the one thing they ALL have in common at the foundational level is the electrical imbalance that is caused at the cellular level.
                    There have been hundreds of people that has give an explanation to cancer.
                    I spent almost a decade reading and compiling information about those works.
                    It's awesome the amount of information anyone can find about people that have developed explanations and "cures" to cancer.
                    In my point of view cancer is a protective mechanism that the body uses to prevent premature death of the cells when they're exposed to an antinatural electro-chemical environment.
                    The body is a really complex electro-chemical device and any disease (including aging) is a loss of the harmonic balance of the body.
                    The cells get their energy from the oxidation that happens in the body. The fuel is alkaline (levo-rotation) particles. When the oxidation happens, that rotation becomes destro-rotation (acids) and the amount of energy that the cells can get from d-rotation is much more less that the energy they can get from l-rotation.
                    While the cell is exposed to acids, the static charge is altered and the cell activates a mechanism based on the information of that static field (cellular differentiation). When you restore the electrical equilibrium then the cell can come back to its original state because the cell has memory and it can restores its vibrational equilibrium thus causing cellular re-diferentiation.
                    That is complex to explain since this process involves hyperspace exchange of energy at the cellular level and more exotic explanations.
                    The cellular water is also of an extreme importance since the water acts as a scalar capacitor and stores energy and information which the body employs to perform hyper-spatial tasks.
                      electrical equilibrium and cellular water
                      Exactly! This equilibrium is lost when cellular efficiency declines with unopposed oxidation. That is the main point to the Cancer is a Redox Disease article. It is all electrical imbalance at the foundational level.
                      Ideally, balanced cellular water should mathematically be a salt water but is not really a sodium chloride solution - it is the balanced mixture of reduced species molecules and reactive oxygen species. Together, the overall sum total would be salt water if they reacted with each other and became neutral but of course they don't since they're stable in their reactive forms.
                        Very clever observation Aaron.
                        When I write about water I mean the static energy imprinted in water. What do you think about the relation of water minerals and water energetic structure?
                          Apple seeds
                          I heard that eating apple seeds are good against cancer cause the seeds have siniade which is a very toxic substance but if taken in little dose found to be good.
                          • #14
                            and also others seeds that contains B17 vitamin.
                            • #15
                              B17
                              In the middle east and and surrounding areas such as Turkey, people have eaten the seeds of Apricots for centuries. The incendence of cancer is hardly mentioned there. B17 is definitely a preventative for cancer. Good luck. stealth
