The Gizeh Pyramid Plateau, an ancient technical plan???
  • The Gizeh Pyramid Plateau, an ancient technical plan???
    Did the designer(s) of the Gizeh Pyramid complex once leave a message that was more sophisticated than merely being able to somehow calculate the exact length of a solar year or to deduce the dimensions of this realm ??? It may just be a crazy idea, maybe not.
    This map is a screenshot from the book “We, the Skytians – The Lie of the Land of AEgypt” by David Alan Ritchie. Free pdf on archive.org
    The measures & distances are in Royal cubits. The lines in red David draw on this scale represent 7 cubits. He based his calculations on the measures and information from Flinder Petries measurements of the pyramids in 1880-82.
    The black lines around the pyramids are ways (causeways) that have been precisely cut into the rock. With some kind of Laser technology, not hammers and cisels.
    Some time ago I read bits of The ancient cubit and our weights and measures by Sir Charles Warren, he mentioned the length of 1 side of the Great Pyramid was 1/8 of a minute of arc at latitude 30? N. I checked that… but NO, it is in fact 1/8 of 1 equatorial minute. But the MILE is almost exactly 1/8 of 1’ arc of latitude 30?N.
    1’ arc at latitude 30? N = 1604.1388 m, which is only a difference of 5.2052 m to the actual 1609.344m = 1 mile
    Great Pyramid, Side length = 1/8 of 1 minute of arc = 440 Royal cubit (RC)
    1’ arc = 1 nautical Mile = 1,852 km , 1852 m = 1.150779 mile
    1852.3m = exactly 1 Equatorial mile
    Official measures of one side +/- 230.34 m – 230.75 m
    1/8 of 1852 m = 231.5 m = 440 RC
    1 RC = 1/440 of 1/8’ arc or 1/3520
    = 0.52613636m = 52.613 cm
    = 20.718 inch
    Second pyramid, Side length = 411 RC
    411= 3*137 and 137 is the 33th prime number.
    Official side length: 215.16 m.
    Calculated side length: 411/440 = 0.9340909090 = cosine
    Inverse cosine 0.9340909090 = 20.918232?
    1852 m * 0.9340909090 = 1729.93636 m
    = 1’ of arc at latitude 20.918232? = 20?55’ 5.6352’’
    1/8 of 1729.93636 m = 216.242m
    Third pyramid, Side lengths 200 x 196 RC
    Official measures 104.6 x 102.2 m
    Calculated measures, repeat procedure
    105.207272 x 103.1227272 m
    = 1/8 of 841.818181 resp of 824.981818 m, corresponding to 1/8 of 1’ arc at latitude 63.547576?, resp 62.944308?.
    Inbetween I read fractions of the Rhind papyrus
    The designer(s) of the pyramid buildings worked with whole numbers and fractions thereof. Everything was a fraction of 1. 1 was the whole, the complete, also called Wedjet. The famous Wedjet Eye (Horus Eye) was a help for pupils to study mathematical divison by multiplying with fractions.
    All ancient measures used were fractions of 1. It can also be seen in the Vitruvian man.
    Example: The Zereth, Span was equivalent to 3 palm or 12 Finger or 1/8 of 1, the Ammah or cubit was ? of 1.
    What if the Gizeh Plateau was ? of 1? Multiply and mirror, this is the result
    Now it looks like a technical drawing. Did the designer(s) leave a plan ??? Could it be for some magnetic propulsion engine? Or sth else?
    The ways, cut in rock, must have a meaning. The squares surrounding P2, the corner is where the causeway from P1 leading to sth North East is changing its angle. The line of the outer square ends between 2 Queen Pyramids, That’s not a coincidence.
    That causeway from P1 starts now between the 2 x 3 Queen pyramids and touches the corner of the inner ones. They are now 2 x 6 total. Each side has both polarities.
    The center of the second pyramid passes right through the head of the Sphinx. (Represents the Sun, thus magnetism? Or heat ?) The 4 Sphinxes incl 1 of the “temples” now in 4 pyramids, it looks like a quadropole generator. The 2 sphinxes on the right side are covered in my image.
    Well, it’s not a high precision drawing, it’s made in an image editor program, not a vector program.
    There is so much more, haven’t even started looking at angles, ...
    From David Alan Ritchie: the dimensions of a room, or space are important, because they produce frequencies. So it might be, that it works or is started with frequency induction, 3 different harmonic frequencies united. -> Kings Chamber.
    I don’t know if this is the right place to post “crazy stuff” like this … but right now I’m looking for some inspiration. Yeah, and I would be glad to know if Gamebeir is still alive, he’s been inactive for more than 1 year here.
    Hello - Jaska2 - The Giza Pyramids are on of my fun research projects of life; I have made a 10 years research into the locations dealing with the system of numbers relating to the magic of
    the designs do everything anyone wants them to do;
    part of what I have done is relocate a little bit to the right locations in feet and inches showing that the feet and inches have not changed in thousands of years they relate in the same way as when the pyramids were built thousands of years ago; the proof of this is shown very simply shown below; there are 125 of these circles formation of points to the corners and center location being so close to the point; there is no quest it is real;
    first; the locations in feet and inches; notice the distances from the edges and sides; all have means to how the cosmos is designed;
ID:	516743 The size of the pyramids have been changed be stay within the size they are in real life;
    putting them in circles of 500 feet / 1000 feet and 1071 feet the 1071 is a very important number in itself;
    next is show on of the corner to center circles the produce a very interesting number 365 25 15 ( the earth year ) in order to have this effect happen it is a billion to 1 ( there are at least 3 of these 356 locations that happen that is trillions to 1 in producing this cornering dimension effect;
    from the corners the offset is about 0.006 inches - The in itself is impossible to happen;
    Like I said; I have produces thousands of these feet and inch designs based on showing that feet and inches have NOT changed in thousands of years and used in the Pyramid designs;
    As impossible as this sounds ( it is all real )
    Din ma Tom Wlazlak
      Hi Tom,
      you seem to know how to calculate those values :-) What program do you use to draw the circles around the pyramids?
      I am not used to measures in inch and foot, but the metric system.
      This is what I calculated for the ancient measures, always fractions of 1, using the Vitruvian man.
      This is based upon the Royal Cubit of 52.62 cm, as 1/440 of 1' of arc at the equator.
      For the inch, the difference is merely about 1 mm. Primitive inch 2.64 compared to 2.54 cm as used today
        hello, Jaska2 - 440 times 12 = 5280 feet = 1 mile() times 12 = 63260 inches
        20.625 inches = 1 royal cubit; / 12 = 1.71875 ( multiplayer ) from Royal cubic to inches
        12 inches = 30.48 CM
        1 inch = 2.54 CM
        royal cubits = 3072 = 5280 feet or 1.71875 times 3072 = 5280 feet
        92.9 million miles from the earth to the Sun
        201.5 times 24 = 4836 or the distance from the sun to Jupiter ( small Pyramid in royal cubits )
        482 feet is the height of the 440 rc or 756 Pyramid or 280.5 rc height
        Starting at the 293 prime number times = 85849 is the relation to ( Noah's Ark) to feet and inches : being 30 50 300 royal cubics or in feet 51 - 85 - 510 feet or 3530 or the earth 2 year cycle;
        36525150 times 2 = 7,3050300
        interesting right; there is so much more; Din ma Tom
          hello pyramid lovers; I have asked myself why is feet and Royal cubit related as Old as the hills;
          this is the locations found on the internet of the Pyramids in Royal cubits
          The side length is 1417.5 Royal cubits and the top is 1732 total side to side length;
          pyramid sizes are small = 201.5 : 411 - 261 height and ( 440 height is 280.5 (( deg. of sides is 51.85 510) angle
          1 mile is 5280 feet = 3072 royal cubits / 12 = 256
          notice the rad. of 256 feet on this drawing that is made from the same layout shown above in feet and inches
          5280 / 256 = 20.625
          3072 / 4 = 768 that is the speed of sound in miles per hr.
          3072 / 8 = 384 That is the inches of travel of gravity per second per second;
          384 / 12 - 32 feet per second per second;
          32 times 24 = 768 speed of sound 24,000 miles earth circ. 24000 / 182.5 height of the 440 pyramid = 131.5 a point of location on the 440 pyramid;
          293 to the 17th power is the center of our galaxy 17293 square root = 131.5028 () 5280 is a mile
          of course 5028 times 24 = 120672 and the feet around the earth is 12 672 0000
          by the way 67.2 million miles from Venus to the sun;
          one more 36525 drawing -- That make a big number to 1 odds of possible in happening on any layout on the planet earth ? ( This is one of my hobbies ) I have many;
          the offset is 0.036 inches in 36525 feet that is 6,917 miles rad / 13,835 miles circ. somewhat crazy odds of happening at all;
          Din ma - Tom ( oh ya, 1417.5 times 4 = 5670 (( 567 times 3 = 1701 times 3 = 5103 Noah's ark 51 foot 30 cubit () 1701 times 5 = 8505 or 85 feet or 50 cubits reversed 1071 -- all fun stuff
          3 square root = 1.732
            Hi Tom,
            The measures we use today have been “standardized” in the 1800s. Like if you search for the length of 1 old “Elle” German measure, which is the equivalent of the cubit ( ? of 1) (Elbow to tip of middle finger) and there were many in use, although the differences were not very large.
            When looking at the different miles (nautical, statute, UK, US…) I found that scolars discussed about the value of 1 Talmudic mile, varying from around 960 m to 1152 m for 1 mile. They base their calculations on measures in the Bible.
            Temples, which had to have been built according to certain dimensions or ratios. IMO, the different values result from different places and that the ancients used the appropriate measure (ratio, fraction) according to the latitude they were.
            960 m would be latitude 58.783415?
            1152 m would be 51.542826? (Avebury)
            That’s the land of Great Britain, Scotland, Ireland and there are claims that this was the true “Holy Land”. Edinburgh being the Jerusalem from the Bible.
            The measures in use would always have been fractions of 1.
            From the Rhind Papyrus: It's obvious that they used another way to calculate back then. See what I mean?
            IMO: Pyramids, Temples, Churches, therebefore Stone circles, etc, all are built on certain places, that some say they are connected through LEY Lines. I think that all of these buildings were also connected through the Frequencies which they produce, due to lengt/wide/breath .. most of the temples /churches have a crypt, similar to the Kings Chamber in the Great Pyramid.
            These places radiated harmonics of the fundamental frequency of this realm. It would have kept ALL that is in harmony, balance. This is what I would call, Paradise, or Golden Age. This sacred harmonic frequency system got destroyed and now we truly live in the Land of CONfusion
            Maybe … maybe the designer(s) left clues not only about the dimensions and other physical aspects concerning this realm, but also did encode the mechanism of Advanced electro-magnetic technology? Maybe it only works with the correct ratios, fractions, angles, frequencies ?
              Hi Tom,
              IMO: Pyramids, Temples, Churches, therebefore Stone circles, etc, all are built on certain places, that some say they are connected through LEY Lines. I think that all of these buildings were also connected through the Frequencies which they produce, due to lengt/wide/height .. most of the temples /churches have a crypt, similar to the Kings Chamber in the Great Pyramid.
                hello, Jaska2 - or 0.66666 = 2/3 plus 0.5 = 1/2 plus .333333 = 1/3 plus .25 = 1/4 == 1.75 () 700 /1.75 = 400 and using thus; in the same way gets the same results;
                3 sailors go ashore and need a room for the night; they see a hotel and go in the hotel keeper says the room is 30 dollars for the night; so each sailor pays 10 dollars
                after a bit the hotel keep has a change of heart and thinks because they are sailors they should get a break; so he sends the bellhop back with 5 dollars to give back to them
                the bellhop not knowing how to divide 5 / 3 ways decides to keep 2 of the dollars for himself and give back 3 dollars ( one dollar to each )
                So each sailor only payed 9 dollars ( 3 times 9 is 27 plus the 2 dollars the bellhop kept that makes 29 dollars ??? what happen to the other dollar? it started at 30;
                din ma Tom
                  hello again; my friend; from one hand to another; if a pyramid has a base of 400 cubits and the height is still 93 and a 1/3 the sides are much easier to gather by simpler means; somewhat?
                  400 by 400 across corner to corner is 565.685
                  at 93.3333 height --- angle 25.017 --- 25.017 times 16 = 400.272 ( there is a 272 size pyramid in Egypt ) interesting 17 times 16 = 272 (( 17 times 51 = 867 ))
                  on Oak island - Nova Scotia There is an OLD rocks in the shape of a cross they weigh about 20 tones each the distance between 293 + 429 + 145 = 867 feet; cross is 720 feet;
                  3050300 times 17 = 5185510 --- is the rocks on Oak island related to numbers found in Egypt located across Oceans and thousands of miles away
                  The rocks were placed thousand of years ago on the island; maybe? ( 293 plus 429 = 722 ) in Russia the largest Pyramid ever found has a base of 1440 and is 722 feet high
                  and angle corner bottom to top
                  18.262 deg. There is also a 262 base pyramid in Egypt -- 18.262 times 2 = 36.524 ( the real earth year is 365.243 about
                  Again; all fun stuff; din ma Tom ( it is not the size it is the meaning of the size that matters )(
                    Hi Tom,
                    Well, there are but 3 people, they pay (10-1) +(10-1) +(10-1-2)
                    I never heard of large pyramids in Russia, and all I could find about large Russian pyramids is 2 on Kola Peninsula .. was a fake news article. The fotos show the pyramids on the Pharao Island (Faroer)
                    https://leadstories.com/hoax-alert/2...peninsula.html
                    It would ofc be huge to discover a pyramid that hasn’t been entered so far.
                    It’s very likely that one or more large objects were removed from the Kings or Queens Chambers through what is called the forced entry by the Arabs. They did not dig that tunnel, they just had to dig a small part around the granite plugs that close the ascending passage after they had remove a cover stone that was hiding those granite plugs. Discovered not by accident.
                    There is a “plan” of the passageways in what is called “Trial Passages” .. so it’s very likely there is another passage, leading first vertically on the joint of ascending & descending passages that could lead to another chamber, or even more rooms
                    https://thehereticmagazine.com/the-trial-passages-a-message-in-stone/
                    I wasn't even particulary interested in the Gizeh pyramids, until I discovered that the side lenght is 1/8 of 1' min arc (equatorial). That's why I think there is much more encoded in the whole complex than merely the exact length of the solar year and other measures one can find by calculating.
                    But as I said yet:
                    Taking the Gizeh complex as 1/4 of 1, the mirroring & that resulting plan might just be a CRAZY idea ... unless someone with knowledge could recognize a scheme or technical plan for some electro-magnetic propulsion technology or similar
                      This is a very interesting article … it truly resonates !!!
                      https://www.willemwitteveen.com/article-1/
                      The author Willem Witteveen suggests that the Great Pyramid was a hydroxy power plant.
                      The RESONANT frequencies (the double of the Fundamental frequency) produced by the Kings Chamber did split WATER or saltwater in into hydrogen and oxygen.
                      This chemical energy was then converted into electrical energy and heat by electrodes (2 metal rings that are visible in an air shaft) releasing again WATER .. true alchemy, true clean energy
                      The author also hints that there’s too much at stake for scientists & economists for this natural technology to be used.
                      Yes indeed, this is a “$?@v€ry plantage” and The Hierarchy Enslaving You would loose power & CONtrol. THEY have already been preventing such natural technologies to be released & will continue to do so in the future!
