Disaster prediction App. Suspicious Observers
  • #31
    The PTB are on the warpath. Many sites gone now. http://rexresearch.com/stuff/12020stuff/12020stuff.html
    Dutchsinse has no content, noted by Rex Research
    We are already experiencing increased UV radiation. Evidently significant amounts.
    There is a crop circle depicting a solar flare of a magnitude that would impact earth and the moon.
    Also in the Suspicous Observer video they found evidence of vitrified rock on the lunar surface. Lots of it evidently.
    It does appear to me that this is what they are trying to prepare for with an alternative 3 plan.
    A space based off world civilization, an undersea survival dome, and massive tunnel projects.
    Some under the guise of transportation improvements.
    • #32
      Not sure what is going on with Dutchsense.
      "He had a 2 day internet outage. Nothing to do with YouTube."
      "he has NOT been banned. He has chosen to the delete the content himself."
      • #33
        The sun is slowly awakening for solar cycle 25. Our magnetosphere is weakening. The end result, the atmosphere is getting more of a charge. There was a lightning bolt recorded that lasted 17 seconds. Free energy in the sky.
        • #34
          There is a new paper out and, it looks BAD.
          "The cycle that just ended, Sunspot Cycle 24, peaked with a sunspot number of 116, and the consensus forecast from a panel of experts convened by the National Aeronautics and Space Administration (NASA) and the National Oceanic and Atmospheric Administration (NOAA) is predicting that Sunspot Cycle 25 will be similarly weak. The panel predicts a peak sunspot number of 115."
          OK, the consensus was for a weak cycle 25.
          "In direct contradiction to the official forecast, a team that includes University of Warwick scientists and led by the National Center for Atmospheric Research (NCAR) is predicting that the Sunspot Cycle that started this fall could be one of the strongest since record-keeping began.
          In a new article published in Solar Physics, the research team predicts that Sunspot Cycle 25 will peak with a maximum sunspot number somewhere between approximately 210 and 260, which would put the new cycle in the company of the top few ever observed."
          "If the new NCAR-led forecast is borne out, it would lend support to the research team’s unorthodox theory – detailed in a series of papers published over the last decade – that the Sun has overlapping 22-year magnetic cycles that interact to produce the well-known, approximately 11-year sunspot cycle as a byproduct. The 22-year cycles repeat like clockwork and could be a key to finally making accurate predictions of the timing and nature of sunspot cycles"
          Cycle 25 has started out stronger than generally predicted. If Warwick is correct, man will soon be entering a post-electricity phase of his history
          • #35
            Queensland power had an explosion and fire at a power plant
            "CS Energy said the fire broke out in a turbine hall at the Callide Power Station in about 1.45pm, causing the three units that were generating power at the time to go off line."
            This happened at the exact time that a solar storm hit,,,, the same area,,,the same time. How does a fire break out in a turbine hall? Too much trash left lying around??
            Nope, the induced currents in the earth resulting from the impact of the CME coupled to the generators.
            Geomagnetically induced currents in power grids.
            • #36
              the other failure was that pipeline that failed at the exact time and place that CME arrived at earth,
              I know the news said it was hackers, but no one had ever herd of them before the event, and they are gone now...
              seems to me like it is time to get ready for spotty electrical service
              • #37
                If you read up on the hydro Quebec event of 1967, the transmission lines picked up energy from a huge mass of solar plasma.
                The Australian event seems to show a direct transfer of energy right into the generators.
                Time should clarify this but, they didn't lose their transformers.
